Ok my car overheats when at idle or under 20mph or less but it only seems to do it at night when the air is cooler which I find odd. Durning the hot day it has never done it. but when this happens once I kick on the heater or get moving it cools down. Water pump is good. I was think relays for the fans or maybe the stat is bad.
check thermostat. make sure there is the correct amount of fluid in resivor tank.
Going to check the stat here later today. And yea when I got the car it had a coolant leak which I fixxed. The resivor was split and I replaced that and the whole system has fresh collant in it.
Oh since I have to remove the intake can the gaskets on this be reused or they need replaced?
