:banghead:
OK so I'm over heating. I have a `97 Interpid 3.5L possible issues (that I can think of),
Raditor cap (New)
Thermostat (New)
Water pump (New)
Hoses (no leaks and have good flow of water)
Radiator (good flow; warm to touch indicating flow)
Heater core (heat works and no water present on passanger floor)
Coolent (water now untill I can isolate the problem and fix it then will go 50/50)
Fans (currently have both fans on at all time, while car is running)
Head Gasket (NO oil in water or water in oil, no white smoke out exhaust, no water vapor out the exhaust either) doing a compression check soon what should it read?)
I have bleed the system over and over again how long should this take I have had the car running for over an hour still getting bubbles.
the Car doesn't over heat while ideling in park. But while driving I have about 2 miles till I overheat
Any thoughts or subjestion are welcome
Thank you.:banghead::banghead:
Raditor cap (New)
Thermostat (New)
Water pump (New)
