1 - 2 of 2 Posts
seems to have started after otis installation. 93 BCM in a 96 intrepid. otis seems to work fine, tho i don't get PASS msg when i press the two inside buttons on the otis. Replaced the thremostat, coolant temp sender. still no fans. i replaced the under the hood low fan module with no success. then i pulled the low fan module alltogether and the fans came on high. and stay on all the time. they also stay on all the time (high) when i disconnect the coolant temp sender. i got 5volts at the coolant temp sensor. havn't checked the voltage at the intake air temp sensor yet. any other ideas? thx in advance, jack
96 intrepid, 3.5l
1 - 2 of 2 Posts
