i've got 99 with the 2.7 - and just recently the car started overheating when idling/sitting in traffic. its fine on the freeways. i was thinking the fans, but they are okay, and maybe even the thermostat, however, if you do the usual of turning on the heat in the car when it starts to overheat, it will come right back down to temperature. this made me think maybe its low or it has an airpocket in the system. does anyone know if our cars have a pressurized system because i'm hoping a flush and re-pressurizing would fix the problem.
any other suggestions?
thanks fellow dodgers
all liquid cooled engines develope pressure after warm up. Our Treps are designed to have no air in the system. When filling the system you must open the bleeder valve located near where the upper radiater hose is connected to the engine. After filling and bleeding any remaining air will be removed at the de-aeration bottle (the bottle with the pressure cap on top) as long as the bottle is filled with coolant up to the fill line. Your trouble of overheating at idle but not on freeway, with both fans functioning can be caused by a few different things. Including :Low coolant level (air in system),dead bugs and other assorted filth in the fins of A/C condenser core (in front of radiator), water pump,clogged coolant passages in radiator, thermostat,. I put these things in order of most likely to least likely in my opinion. note:when thermostats fail they usually are stuck open causing engine to run cold. water pumps normally don't fail to pump coolant, they like to leak and become noisy. If the pump is leaking your coolant level will become low and you'll have air in the system. If the pump on a 2.7 is leaking it is a very bad thing. That coolant will get into your engine oil and render your oil useless and cause lots of damage to your bearings and break your timing chain. Check your engine oil ,if it looks milky or creamy and or has an unusual aroma, then you got coolant in your oil. In this case fix it on the spot or have it towed to a shop.
Discussion Starter · #3 ·
thanks man, that helps alot. I think i just got air in the system when i was checking the levels routinely. no leaks or anything and the oil looked great when i changed it last week. even cut open the oil filter, and things looked okay. i've heard horror stories about the 2.7 and i'm staying ontop of things. everything has been fine for a year, and already past the 80K mark.
when you fill the antifreeze up, is this valve (i know the one your talking about) something you can do in your drive or you have to get it taken in?
The bleeder valve has a nipple to attatch a length of 1/4" I.D. clear vinyl tubing and run the tubing over the front of car into an empty container. When filling the system trapped air goes through the tube, when you see coolant going through the tube, then you know you have all the air out and system is full. any remaining air will come out in the de-aeration bottle after about an hour of normal driving. Yep I've heard the horror stories also,but there are plenty of 2.7s that live a long life no thanks to Chrysler but more thanks to owners that know the 2.7 weaknesses and can stay ahead of the game by going beyond "normal" maintenance. If for some reason your coolant continues to mysteriously disappear, keep a close eye on engine oil condition until you find out where the coolant is going.
Not just treps, but all liquid cooled engines. Any air in the cooling system leads to problems like no heat in the car and hot spot in the engine. DC was pretty keen when they put a bleeder on the engine. All liquid cooled engines have to be bled of air, some are just easier than others. Some Fords had a "burp" hole in the t-stat that allowed air to be bled past the t-stat while the engine was still cold. While there have been problems with the original design of the bleeders on these cars, hands down the concept was a good one.
Try changing your radiator cap. I recently changed mine and it solved my coolant bubbling problem. There is a new part number for the cap too. I don't have it though. It looks different and better now IMO.
