I have a 2004 Dodge Intrepid 2.7 and I'm getting OBDII Code P0480 and that's all. Both fans will turn on when the A/C is on. With the A/C turned off, no matter how hot the engine is, no fans will not come on at all. I've already replaced the Radiator Fan Relay. Same results.
Could it be the Coolant Temperature Sensor? I wouldn't think I would have bad fans since they do work well on High when the A/C is on.
Any help would be greatly appreciated.
