1 - 9 of 9 Posts
does anyone know what the code is p068 also its an 02 trep i did a 3.5 conversion started it for the first time its running rough when i try to rev it up as soon as i pass more then 2inchs down the pedal is starts to bogg and wants to shut off so i let of the gas pedal to keep it running ???????
That code is MAP(manifold air pressure)-throttle position correlation...
Did all of your connections find a home on the vehicle wiring?
Did you the existing ECU(2.7), or one from the donor car?
i dont see anymore wires im using the existing 2.7 ecm thats with the the car they say i can run the 3.5 with that 2.7 computer im also getting but i drove the car for like 20 mins came home shut it off and then i turned ign on 3times now i dont show p068 it shows p0108 and p0151 the p068 is gone i know what those other ones are but what should i do thanks
First of all, the P068 is missing a number. The P codes are 4 numbers not 3.
I can't find anything close to it, so when I get home, I'll see what my code book has. Here's info on the other two.
P0151 is a problem with one of the O2 sensors Bank 2 (drivers side I think) upper
P0108 is a problem with the MAP sensor voltage (too high)
i know what they are what should i do and were is the map sensor located. voltage too high what excat does that mean is it bad change or ????
P0068
Manifold Pressure/Throttle Position
Correlation
MAP sensor signal does not correlate to throttle position
sensor signal. Possible vacuum leak.
Oh yeah, welcome to the High-Output SE club!!!
1 - 9 of 9 Posts
