1 - 20 of 28 Posts
Farticcus of Plenticcus
Group,
I thought it would be a good idea to have a thread to be able to access part numbers rather easily. Perhaps we could get this stickied....
This will be part numbers that we have come across over the years.
I would like to combine them in a single post in this thread.
Hope this is useful...
Engine / Powertrain:
4865032AA - Prowler NAMEPLATE, 3.5L 24 Valve
5019925AA - WIRING 2 WAY (adapting the 160A Police Alternator to 98-01 cars)
6504848AA - SCREW, Pan Head, Ignition Coil Mounting BOLT
4591250 - Emission system - Egr system - Seal SEAL, Charger, Magnum, 300 2005
4591251AB - Emission system - Emission components - Egr tube - Clip Clip 1999 - 2001
6101953 - BOLT, Intake Plenum to Intake Manifold m6x1.00x85.00
4648832AA - 10W30 Mobil 1 Oil Cap
4591959AA - 0W40 Mobile1 Oil Cap (SRT8)
Interior:
56042756AG - 2002 Chrysler 300m EVIC (IMPG & TPMS)
Suspension:
4895686AA - Front Springs (Special)
4782233AA - Insulator Pads
4895561AB - Front Left Strut (Special)
4895560AB - Front Right Strut (Special)
4782668AA - Rear Springs (Special)
4895003AB - Insulator Pads
4895002AA - Insulator Pads
4782667AA - Rear Dampers (Special)
4782855AA - Rear Sway Bar (Special)
1st Gen FTW - It's AutoMedic!
Tom - you had just posted the Prowler intake sticker in the whore thread - don't forget that one.
I propose it be set up like a how-to. A discusion thread, and a number thread - the number thread be locked and modified by a Moderator, but the discusion thread be where new numbers are poured in.
Comments?
Comments?
Sounds good to me.
That rhythm is INFECTIOUS.
4536492AB - SEAL-CAMSH
4556518AB - PLATE-CAMS
Rear cam covers and gaskets. Buy one of each for each side. These supersede the original plate & O-ring setup. Cost me under $10 total for two of each.
These fit 3.2's - but probably 3.5's as well. May want to verify with your local 5-Star.
Someone in the community just posted multiple years of the factory parts manuals in pdf. Might have been here or over at lhf.
Why not start off with a link to the pdf parts manuals and then list other things like prowler part numbers and any clarifications/supercessions to part numbers listed in the factory part manuals?
A good example of this could be the industry standard oring you can use to replace the leaky factory one on all the 3.5HO MTV valves. Another one is the rear cam seal stuff posted just above me. That huge list of OTIS/EVICs would be helpful too
21102 - Aeromotive 32% OD Pulley
465-K060490 Gates Belt needed for the ASP UD + Alt OD (Aeromotive) pulley install
5060490 - Dayco Poly Cog Belt needed for the ASP UD + Alt (Aeromotive) OD pulley install
I don't have the p/n's for the O-Ring...if you have access to them, post them here.
Discussion Starter #11
PCM Information from the Parts Catalog:
1998
4606460AQ 2.7 California Emissions
4606475AH 3.2 Mexico Emissions
4606680AK 3.5 w/Leaded Fuel
4606735AL 2.7 Mexico Emissions
4606820AO 3.2 Federal Emissions
4606830AR 2.7 Federal
4606840AN 3.5 California Emissions
4606850AO 3.2 California Emissions
4606890AB 3.5 California Emissions, High Speed
4606970AM 3.5 European Emissions
4606985AB 3.5 Federal Emissions, High Speed
1999
4606495AC 3.2 Mexico Emissions
4606675AE 2.7 European Emissions
4606680AM 3.5 w/Leaded Fuel
4606785AB 2.7 w/Leaded Fuel
4606810AP 3.5 Federal Emissions
4606815AK 3.5 Mexico Emissions
4606840AP 3.5 California Emissions
4606890AD 3.5
4606970AO 3,5 European Emissions
4606985AD 3.5 Federal Emissions, High Speed
4896025AB 2.7 Mexico Emissions
4896120AC 3.2 Federal Emissions
4896230AC 2.7 Federal Emissions
4896250AC 3.2 California Emissions
4896260AC 2.7 California Emissions
2000
4606614AF 2.7 w/California Emissions
4606682AC 2.7 w/Federal Emissions
4606775AA 2.7 w/active intake w/European Emissions
4606806AA 3.5 Magnum w/Federal Emissions, High Speed
4606980AA 3.5 w/Leaded Fuel
4896185AA 2.7 w/active intake w/Leaded Fuel
4896240AF 3.5 w/California Emissions
4896272AA 3.5 w/Federal Emissions
4896344AA 3.5 w/Mexico Emissions
4896345AA 3.5 Magnum [NAM,NZ5]
4896350AE 3.2 w/California Emissions
4896360AG 2.7 w/ active intake w/California Emissions
4896370AB 3.5 w/European Emissions
4896462AA 3.2 w/Federal Emissions
4896530AA 2.7 w/active intake w/Federal Emissions
4896632AA 3.5 w/Federal Emissions, High Speed Engine Controller
4896653AA 3.2 w/Mexico Emissions
4896742AF 3.5 w/California Emissions, High Speed Engine Controller
4896828AB 3.5 Magnum w/California Emissions
2001
4606678AA 3.5HO Mexico [NAM-NZ5]
4606678AC 3.5HO Mexico [NAM+NZ5]
4606739AA 3.5 Mexico [NAM+NZ5]
4606821AA 3.5HO Leaded Fuel [NAB], Export
4606892AB 3.2 US 50 States [NAS]
4606895AB 3.5HO US 50 States [NAS-NZ5]
4606984AB 3.5HO European [NA3+NZ5]
4896146AB 2.7 US 50 States [NAS]
4896237AB 2.7 w/active intake European [NA3+NZ5]
4896358AA 2.7 w/active intake Leaded Fuel [NAB], Export
4896467AA 3.2 Mexico [NAM]
4896541AA 3.5HO US 50 States [NAS+NZ5]
4896572AC 3.5HO US 50 States [NAS+NZ5]
4896925AB 2.7 w/active intake US 50 States [NAS]
2002
4606683AE 3.5HO [NAS,NZ5] Up to 8/27/01
4606789AD 3.5HO [NA1] Up to 08/27/01
4606871AD 3.5HO [NAM,NZ5] Up to 08/27/01
4606872AA 3.5HO [NAM] Up to 08/27/01
4606873AA 3.5HO [NAS,NZ5]After 8/27/01 and up to 11/05/02
4606876AA 3.5 [NAS] After 8/27/01 and up to 11/05/01
4606877AA 2.7 [NAS] After 8/27/01 and up to 11/05/01
4606878AA 3.5HO [NAS] After 8/27/01 and up to 11/05/02
4606879AB 3.5 Magnum [NAS]
4606904AF 3.5 [NAS] Up to 8/27/01
4606905AC 3.5 [NAM] Up to 08/13/01
4896095AE 3.5HO [NA3] Up to 08/27/03
4896124AF 3.5HO [NAS] Up to 8/27/01
4896210AB 3.5HO [NA3] After 11/05/01
4896211AB 3.5HO [NA1,NBJ] After 11/05/01
4896212AB 3.5HO [NAS] After 11/05/01
4896213AB 3.5HO [NAM,NZ5] After 11/05/01
4896220AB 2.7 [NAS] After 11/05/01
4896221AB 2.7 [NA3] After 11/05/02
4896222AB 2.7 [NA1,NZ5] After 11/05/01
4896223AB 2.7 [NA1] After 11/05/01
4896224AB 3.5 [NAS] After 11/05/01
4896225AB 3.5 [NAM] After 11/05/01
4896226AB 3.5HO [NAS] After 11/05/01
4896227AB 3.5HO [NAS,NZ5] After 11/05/01
4896228AB 3.5HO [NA1] After 11/05/01
4896229AB 3.5HO [NAM] After 11/05/01
4896257AG 2.7 [NAS] Up to 8/27/01
4896348AC 2.7 [NA3] Up to 8/27/01
4896349AA 2.7 [NA1,NZ5] Up to 8/27/01
4896440AA 2.7 [NA3] After 08/27/01 and up to 11/05/01
4896441AA 2.7 [NA1,NZ5] After 8/27/01 and up to 11/05/01
4896442AA 2.7 [NA1] After 08/27/01 and up 11/05/01
4896443AA 3.5 [NAM] After 08/13/01 and up to 11/05/01
4896443AB 3.5 [NAM] After 08/27/01 and up 11/05/01
4896444AA 3.5 [NA1] After 08/27/01 and up 11/05/01
4896445AA 3.5 [NAM] After 08/27/01 and up 11/05/01
4896446AA 3.5 [NA3] After 08/27/01 and up to 11/05/01
4896448AA 3.5 [NAM,NZ5] After 08/27/01 and up to 11/05/01
4896469AC 2.7 [NA1] Up to 8/27/01
4896554AB 3.5 "special" [NAS] After 11/05/01,
4896652AE 3.5 Magnum [NAS] Up to 8/27/01
4896874AA 3.5HO [NAS] After 8/27/01 and up to 11/05/01
2003
4606906AB 3.5 [NAM]
4606907AC 3.5 [NAS]
4896555AC 3.5"special" [NAS]
4896556AA 3.5"special" [NAS, TRG]
4896720AB 3.5HO [NAM]
4896721AE 3.5HO [NAS,NZ5]
4896722AE 3.5HO [NAS]
4896723AD 3.5HO Up to 11/18/02 [NA1, NB3]
4896723AE 3.5HO After 11/18/02 [NA1, NB3]
4896724AD 2.7 [NA1, NB2]
4896725AD 3.5 Magnum [NAS, NAM]
4896727AF 2.7 [NAS]
4896729AD 2.7 [NA1, NB3]
4896729AG 2.7 [NA1,NB3]
4896730AD 2.7 [NA1, NB3, NZ5]
4896730AG 2.7 [NA1,NB2,NZ5]
4896736AB 3.5HO [NA1, NB2]
4896736AE 3.5HO [NA1,NB2]
4896737AB 3.5HO [NA1, NBJ]
4896737AE 3.5HO [NA1,NBJ]
2004
4896500AB 3.5HO [NAS,NX5,XC9]
4896501AB 3.5HO [NAS,XC9]
4896502AB 3.5HO [NA1,NB3,XC9]
4896503AB 3.5HO [NA1,NB2,XC9]
4896504AB 3.5HO [NA1,NBJ,XC9]
4896505AB 3.5HO [NAM,XC9]
4896506AB 3.5 Magnum [NAS,NAM,XC9]
4896507AB 3.5 [NAS,XC9]
4896508AB 3.5 [NAM,XC9]
4896509AB 3.5"special" [NAS,NAM,TUX,XC9]
4896510AB 3.5"special" [NAS,NAM,TRG,XC9]
4896511AB 2.7 [NAS,XC9]
4896512AB 2.7 [NA1,NB3,XC9]
4896513AB 2,7 [NA1,NB2,NZ5,XC9]
4896514AB 2.7 [NA1,NB2,XC9]
Use this post to compare to the information above...
Torontofirecaptain said:
Perhaps this wll stop some of the mis-information and such that has been posted of late (mostly "over-there", not here) about the speed limits on the various controllers.
You will note that the 2000 R/T is the ONLY one domestically with no limit.
1998 & 1999 LH
All are limited to 108 MPH or 132MPH with HS tires.
2000 LH
R/T - Federal/Canada, unlimited………….……. 0406806AA
R/T – LEV unlimited………………….………...04896828AB
Other 3.5 L Magnum…………….………………04606517AF
US unlimited……………………………………..4896632AB
Low emissions unlimited…………………………4896742AG
2001 LH
3.5L Magnum HO………………………………..04896430AG
3.5L Magnum, 114 MPH limit………………..….04606892AD
3.5L Magnum, MOTORSPORT 108 MPH………04896543AB
2002 LH
3.5L HO
NLEV 108 MPH………………………………….5102176AC
NLEV 132 MPH………………………………….5102177AC
R/T NLEV 132 MPH……………………………..5102178AC
GCC 132 MPH……………………………………5103278AB
EUROIII 149 MPH………………………………..5103236AB
R/T Mexic0 132 MPH….…………………………5103239AB
HO Mexico 132 MPH…………………………….5103234AB
NLEV 108 MPH w/o EGR………………………...5102181AC
NLEV 132 MPH W/O EGR………………………..5102182AC
JAPAN, 149 MPH………………………………...5103238AB
3.5L Low Output, all are 108 MPH limit
300M Special, 143 MPH…………………………….5102189AB & 4896554AE
2003 LH
All 3.5L HO engines….108 or 132 MPH for North America, 149 MPH European, 108 MPH Mexican, Gulf coast & Japan.
All Low Out put 108 MPH
300M Special, 132 MPH……………………………….4896510AD
300M Special, 143 MPH……………………………….4896509AD
2004 LH
3.5L HO engine speeds the same as 2003.
3.5L Low output speeds the same as 2003
300M Special, 132 MPH……………………………..4896510AD
300M Special, 143 MPH……………………………..4896509AD
300M Special, 143 MPH, gulf Coast…………………4896515AB
DO NOT USE THE FOLLOWING POLICE PCMs:
2002, 2003, 2004….. #4602305XX (speed limited to 132, but ONLY usable with police BCM.)
O-ring for the MTV on the 3.2/3.5HO engines:
AS568A Dash Number : 136
Width 3/32"
Inside Diameter 2"
Outside Diameter 2-3/16"
I chose an oring made from Viton. McMaster Carr p/n : 9464K136
The Viton can stand high heat and is firm. I had to lubricate the o-ring to get the MTV back on.
If I did it again, I would probably consider just using some Black RTV
Discussion Starter #16
5011114AA - Reuseable Tranny Pan Gasket (good for up to 3 pan drops)
Discussion Starter #17
Underdrive Pulley part numbers (along with associated belts)
aspracing.com Part # ASP801330 $124.95 + shipping
V-Belt #15535 53" Dayco $15.98 from Advance Auto
Serpentine Belt #5060500 50" Dayco $16.98 from Advance Auto
#4060500 is the Goodyear number
Discussion Starter #18
4892293AC
ARM-INLET AND EXHAUST VALVE [Part# 4892293AC]
55077241AB
PUMP, Washer, Windshield
Discussion Starter #19
I have found some additional pulleys that can be used in this application.
Powermaster makes OD pulleys that Jeg's now carries.
The one I went with for my newly rebuilt Police Alternator is:
713-115 - 49mm, Natural Finish OD Serpentine Pulley $7.99 @ Jegs
They also offer these:
713-114 - 54mm, Chrome Finish OD Serpentine Pulley $22.99
713-105 - 49mm, Chrome Finish OD Serpentine Pulley $19.99
713-104 - 54mm, Natural Finish OD Serpentine Pulley $8.99
713-175 - 46mm, Natural Finish OD Serpentine Pulley $21.99
You can look at the PowerMaster catalog here:
http://www.powermastermotorsports.co...talogEbook.pdf
1 - 20 of 28 Posts
