Just trying to verify part numbers before I start my project
#1 - Mopar PN 4897748AB (part in red includes #2 & #3 in diagram)
#8 - Mopar PN 4659430AB (Part in blue)
I'm not 100% sure of the part numbr for #7 (part in green) I was given PN 4483443 but the o-ring looks very thick and sticks out significantly more than #8. I'm thinking that that is the wrong one... or #8 is wrong.
Can someone help me out? Thanks...
Hardwarz
why are you replacing that?
I have no clue about the part number - but I have an important advice regarding the seals shown on a picture as number 7.
First make sure you have an original Mopar part (2 pcs.).
It fits precisely. It is thick. Other orings make funny problems like leaking.
Then remember NOT to put too much of sillicone around these orings.
The excess of sillicone goes inside and likes to push O-rings in - so they protrude inside housing causing flow restrictons (and leaks - sometimes).
I had seen that - so be carefull.
Apply thin amount of sillicone and never on these little seals.
Otherwise you might be forced to redo your job again.
A friend was "helping" me change my water pump and broke a bolt off. I tried extracting the bolt and drilling it out, only to screw up the peice. Now it's being replaced.
Hardwarz
how much is that costing you?
List: $404.80. Dealer sold it to me for $352.00 Part number 4897748AB
I'm not even sure how many man hours is going to go into this project... it's going to be merged with my AC Condenser project.
Hardwarz
$352 for just that one part? #1? if so take it ****ing back you got ripped i got one i'll sell ya for $150
