1 - 1 of 1 Posts
Saw this on the news this morning, maybe you guys might be interested. I checked out the specs of the program, it seems to be a very handy program. . .
http://www.laplink.com/promos/pcmoverzd/default.asp
Click on the left side where it says free copy.
Save Time and Money with PCmover
Studies suggest the average business spends $250 to set up a new PC - but they spend a fraction of that when they use Laplink PCmover.
PCmover makes it simple. Just install the PCmover software, click your mouse a few times, and PCmover does the rest. It really is that simple!
Was it a hassle to set up your last PC? Did you spend hours or even days moving data from an old PC to the new one? Did you lose data during the process? Were you able to find all the old software you needed to reinstall on the new PC? Maybe you tried using an imaging tool like Norton Ghost, only to discover that if the hardware or operating systems on the source and destination PCs are different, it just doesn't work.
Solve all of these problems with PCmover!
With PCmover, everything will transfer - without deleting or changing anything on the old PC and without overwriting anything on the new PC.
Key Features
Moves ALL applications
Simple wizard interface - transfer everything with just a few clicks
Automatic process -PCmover does it all; no searching for hard to find data or applications
Overwrite protection - nothing is overwritten on the new PC
Undo feature - reverse the transfer if you encounter a problem or change your mind
Easy connectivity - use a network (even wireless!) or a Laplink cable to connect the PCs
And PCmover leaves the source PC unchanged, fully intact and functional!
1 - 1 of 1 Posts
