I've been spending more time at the 300M club since I bought the LHS, and I have come up with a couple of questions I couldn't iron out for myself reading the FAQs.
On the other site, they talk about pulling a fuse N or Q under the hood to reset the PCM and TCM, depending on the model year. But they say that it applies to all second gen Chryslers.
Here I seem to understand that prior to 02 Intrepids did not have a TCM. Do I have that right?
Secondly, I have to assume that pulling the appropriate fuse in an Intrepid would also reset the PCM/TCM. True?
I pulled fuse N in my 2002 Intrepid, to reset my engine light and it worked. I'm not sure about the other questions, but if this is what you were looking to do it works.
Not sure about which fuse controls the PCM / TCM.
Prior to 2002, the PCM and TCM was 2 separate computers. In 2002 and up they were incorporated into one computer.
Fuse "N" will reset the PCM in a 2000 car and fuse "Q" will reset the TCM.
Here's my BCM question:
How does one go about enabling the "auto locking" function. I think I saw this somewhere before, but couldn't find it again.
From 300M pages
Quote from the 300M club:
I like most have my car setup so when I drive away, all of my doors lock. If you ever wanted to disable this feature, cycle the ignition switch 4 times, ON-OFF ending up in the OFF position. Depress the power lock switch located on the driver's side door. A single chime will sound indicating completion of this program.
Perhaps it will work in reverse.
