Go to obdii.com. You can punch in your code number or browse them all.
You can retrieve codes, (assuming you have a 98 or newer trep) by clicking the key on and off three times in sucession, then leaving it in the on position the third time. Any codes you have will appear on the odometer screen.
I heard the "key dance" works on the 1st gens also, except the codes don't display on the odometer, the CEL will flash each number of times for each code numbers stored.
