1 - 2 of 2 Posts
I've got a 99 Intrepid with 2.7L. The power steering has a fitting between the high pressure hose and the pump, the fitting has a pressure switch in it. this fitting is leaking where it connects to high pressure hose. I took it apart and didn't see a seal (but it just started leaking last week). I put in various o-rings with no luck.
I went to the dealer (several), their books don't show what kind (if any) seal goes into fitting
Has anyone had this problem. Does anyone know how to fix, what type of seal to use??
Thanks in advance for any advice
I think mine may be leaking as well.....not bad though.
1 - 2 of 2 Posts
