My 01 SE recently developed a whine under the hood which gradually worsened. Just when I had convinced myself (after doing research here) that the problem was most likely a tensioner or pulley, the dealer tells me (yes, I took this to the dealer because I thought it might be a more specialized problem) that "both the power steering and return lines" were leaking and the sound was the pump with low fluid. He said the pump seems still to be OK but to replace the lines is "a bear of a job, about 5 1/2 hours" and quoted me $600. WOW. They won't be doing anything to the pump itself or changing any belts.
I mean, granted, I could have checked the fluid level had I even suspected that (my car is parked long periods of time, and I haven't seen any leaks...does p/s leak only when in use?) but (a) how likely is it that both lines would be leaking simultaneously, and (b) is $600 for this job in the realm of reasonable? It sure seems high to me. I should say that this is a dealership that has always seemed honest in the past, with minimal charges for resolving some past issues.
Should I get a second opinion (in which case if they're correct I'd be out the extra diagnostic time)?
Any help is certainly appreciated.
