1 - 2 of 2 Posts
Anybody else had this problem? I found a leak in my power steering pump and was going to change the entire pump then realized it was leaking directly from the pressure switch. It also threw me the psps failure code. Anybody else had this problem? And does simply unscrewing the old one and replacing it fix it? It leaks terribly through where the switch is screwed in.
Yep, unscrew it, install a new one. Might want to visit the yard, that switch is expensive new.
1 - 2 of 2 Posts
