I know it's not an LH car, but people here seem to know their stuff.
97 cirrus
4cyl
Engine keeps cutting out while driving. If i press the accelerator, nothing happens, but if I take my foot off, usually starts back up again. I am not getting any diagnostic codes or check engine light.
Any one have a clue?
Second question is ac related.
I don't get any cold air. The system is charged, the clutch engages, and the one line gets hot, to the poi9nt you can't touch it without getting burned. The other line doesn't even get cool to the touch. I reqally can't afford to bring it in right now. So if anyone can shed some light on this I would greatly appreciate it.
I would say your fuel pump is about to go. When under heavy acceleration (or in this case just acceration), fuel supply is not enough to keep the engine going. Get your fuel pressure measured to confirm this.
Problem solved, turned out to be mass airflow sensor.
wow that's interesting... Although I can't believe something like a MAF malfunction does not generating a code...
