:confused: I have a problem with the running lights not working on my 97 intrepid. I've checked all the fuses and all appear to be ok. Does anyone have any suggestions as to why my running lights are not operating? Btw, all other lights are working fine and the parking brake was also checked and is not in a stuck position. Please advise.
Thank you in advance
Uhhhhh, pretty sure 97's don't have daytime running lights.
Did you check the Daytime running Lights Module. It is located on the passenger side on the front radiator support in front of the air box. It should look like a little box with a connector going into it. That would be my guess.
Thank you for your help Swartllk! I will forward this info to my hubby whom will hopefully be able to locate this module and replace it if need be.
Thanks a bunch!
