1 - 18 of 18 Posts
After talking to several bodymen I came up with what I hear to be the best treatment of black trim for long term results. Several shops recommended it. One said it will last as long as a year and one said a summer.
Most of us know how good Mothers Back to Black works and some of us know how good Adams VRT works. So I will compare results to these 2 products vs the Forever Black.
Here is the product
$17.90 delivered
4 oz cleaning solvent
4 oz pigment
Applicator tip reminds me of a shoe polish applicator.
The test pieces. (window trim) These were given to me and are in fair shape. Will treat one with Forever Black. The other I will treat half with VRT the other half with Mothers Back to Black. Set them both outside in the elements and see what happens.
Mixed the 4 oz of cleaner with 1 gallon water.
Using a rag I cleaned them both to remove contaminants.
The instructions say to flush well with water after cleaning and allow to dry completely, so I will let them dry over night.
More to come.
I gotta say that I LOVE reading your product reviews Doug. Keep them up!
Applied the Adams VRT, Mothers Back to Black and Forever Black.
I did not apply the forever Black per the instructions by using the applicator. Instead I used a cotton swab to conserve the amount I used. I followed it up with a brush. I think the applicator would provide a smoother blotch free look.
I applied 3 thin layers.
The Back to Black and the VRT went on as a heavy coat allowing it to soak in as much as possible before wiping off the extra.
I have to say the results are very very similar.
Hard to tell the difference, but with a critical eye........
The Forever Black is my barely least favorite
Adams VRT
Mothers Back to Black had the best immediate results by looking the most even and black.
Set them outside to weather a while. Time will tell.
While the test pieces get weathered on the back porch in the sun......I decided to go ahead and apply Forever Black to the windshield trim I am unhappy with.
After cleaning the trim I masked and applied three even coats after each were dry. I love the look. Now if it only lasts!!! The other treatments have always let me down after a little while.
I will post results as I see the changes.
The Womanizer!
That stuff looks pretty good. I wish there was something that lasted on the metal pillars and kept them nice and black!
The Womanizer!
What compound or polish did you use when you buffed them out?
Day 11 since the treatment. It has been hot and sunny and the pieces have been baking in the sun every day. It rained once and I washed them once with a mild solution of car wash soap, rinsed them and wiped them, then let them dry in the sun.
The Forever Black piece still looks great.
I wish Back to Black lasted longer. I like how it looks imediatley after application. A few weeks later, it's back to gray.
guys,one word!! krylon!
i redid all my trim whti it,its bullets proof. comes out matte black,we use them at the paintball repair shop when we do custom stuff,matches a tippman a-5`s paint exactly.
i used a bench grinder and a wire brush to remove old paint and crap.then i use methyle hydrate to de grease. a few good coats and a 24 hour hardening and your done.
get off my lawn
Diug did the trim on the back window of the Special,, looked good at first,, but there now seems to be like a mildew affect going on,,,, gonna have to try it again,,
I have used Forever Black with really good, long lasting results on textured black plastic (such as the door handles of a Neon). I used the shoe polish looking applicator and it went on very nicely. You have to have a shop towel handy to wipe it off the paint, lol - even if you use masking tape I found that it can creep under.
The results are not so impressive on rubber trim as far as I can tell, or on smooth, glossy plastic. However I have not tried the other products at all.
I would definitely recommend this product for textured plastic.
This is a great review. How did I miss these?!?! :)
Discussion Starter #18
there was mildew when we started. We tried to remove it before we put the Forever Black on...... must not have gotten it all.
1 - 18 of 18 Posts
