I an looking into putting a 3.5 engine and trans into a 1969 VW Karmin Ghia. I have done some rough measuring and if I mid mount the engine and trans it can be done with a lot of work.
What I need is some info about the engines and trans.
What year was the aluminum engines 2.7 3.2 3.5?
What is considered the better engines? I have read the post about performance modifications in the 1st gen forum.
For the trans, is the 2.7 trans the same as the 3.5 with the exception of the final drive ratio?
What would be the minimum electronics to run the engine and trans combo?
What are the phiscial dimensions of the engine and trans?
Anything you can tell me would be appricated
Brian
Brian
