99.9% chance no, tow pretty much different engines, with the exception that they bolt to the same tranny.
They are not much different at all. The block is the EXACT SAME, only alum.
1G fuel rail has an inlet on one end, and a pressure regulator/return feed on the other end.
2G fuel rails have ONLY an inled (they are a returnless system.)
if you were to try to goto the 2G rails.. you would have to put a 2G fuel pump/sending unit in the gas tank...........
(as it has the pressure regulator in it insted)
I'm not exactly sure why you quoted me. I was talking about the engines. Not the rails.
I didn't even know we had a return line. That kind of makes things easier for fuel upgrades.
I quoted you because I hate you.
You know it
Just kidding. I just hit the wrong button on the internet... I thinkin I downloaded half it it too... I hope my floppy drive can fit it all, because my hard drive is kinda getting all used up.....
