Transmission Fluid (ATF+3)
  • Quaker State
    Votes: 1 16.7%
  • Castrol
    Votes: 1 16.7%
  • Coastal
    Votes: 1 16.7%
  • Valvoline
    Votes: 3 50.0%
Umm, go with genuine MOPAR from the dealer.
dont know about trans fluid but motor oil i would go with valvoline...
the absolute best thing to do is go to a dealership and get atf 4+ although its very pricey....personally i am running aamco atf3+ and i am changing it frequently
Valvoline for dino oil, but Mopar for the Tranny! :) I don't use anything from Quaker State or Pennzoil...they tend to absorb moisture...
I doubt if there's any difference between major brands. Just be sure you get the right stuff. I think older model 'Treps take 7176, newer ones 9104 or something like that. DON'T PUT IN DEXRON!!
Use ***ONLY*** MOPAR tranny fluid for your trep!!
Use either MOPAR ATF +3 (7176)
or MOPAR ATF +4 (9202) or (9206)
Both of these can be purchased at the dealer.
ATF+4 and get the anti-foam.... don't waste your time with other stuff..and change your filter if not done recently
