So, I have tire pressure sensor on my M and now when I want to change my tires, the guy says that i need new orings/bolt for my sensors. he says, once we remove em and put it back, it might leak. Is this true??
I know its only $2.5 or so each - its just that I have to wait for a week, because my local dealers don't have it in stock.
Also there is only 1 nut that goes with the sensor right??
So all we need is 52088961AA
Ummmmmmmmm, I had mine reused, NO PROBLEMS dude.
I recently had mine changed out to different rims without replacing any parts. 2 months now without losing a single pound of pressure. I can't imagine why you might need new valve stem nuts. Would be interesting to learn the logic.
do these stem nuts go from inside the rims or is it from outside.
like the guy said you might leak air - if i reuse the nuts.
Now if it does, i can just change the nuts myslef right (from outside the tire)??
yeah, i think I am gonna tell him, that you do need a new nut. Anyways, I am done with my work, will leave in a few and of to richmond.
