1 - 2 of 2 Posts
I'm not sure if this is the right spot for this, or if I should have put it in the Audio/Video section, but here is my question:
I have a 2001 R/T with the midline audio system (currently has the RAZ radio).
I found this CD Player with changer controls on ebay - it says it is an RBK from 02-05 models.
If I understand correctly, I would need to get some type of adapter to work in my car? Also, this would work with a 4-disc changer, correct?
Here is the link to the radio on ebay:
RBK Radio
Here is a link to an adapter which I believe I would need:
Adapter
Thanks for any info in advance!
That’s the correct adapter PN (82207541). It takes the 2 plugs you have in the car, and converts them into the one plug that goes into the new radio. It also comes with the antenna adapter.
It’s cheaper to buy it from this Dodge dealer than online.
http://www.newdodgeparts.com/dodge-parts.htm
Just do a search by the PN and you can order it online or print out the search results with the prices and bring it to your local Dodge/Chrysler/Jeep dealer see if they match it.
Item Number MSRP Core Price Price
82207541 $26.00 $0.00 $20.80
Instrument panel - Sound system - Wire connector
Wire connector 2002 - 2003
1 - 2 of 2 Posts
