Gary S -sure you can change the front fascia to one with fog lights. Not only do you need the fascia ,but you also need what are called thermo shields ,these are the tall plastic air deflectors under the fascia on either side of the rad .The ES/RT use the same thermo shield and the SE uses another .They are installed with one plastic rivet to the to metal cover over the rad and two plastic push-pins on the bottom If you try to install the new fascia with the old shields it wont fit
[ October 06, 2001: Message edited by: ottowrkr ]
