OK, so i recently put on R/T Rims with tires, and whenever i turn the wheel all the way to the left or right, it does not turn back by itself as i roll forward, instead it keeps trying to turn the wheel in that direction?
What does this mean, do i need an alingment or something?
Thanks in advanced,
Andrei
That usually indicates a lack of castor in the front, but that shouldn't have changed by simply putting on wheels.
I'd get - or do it yourself, visually - it checked for something either worn or loose.
Toronto-dont know what that means..
D-All torqued to 100 and the pressure is 36psi!
ahh its sooo annoying!
I would go have the alignment checked out dude...if it's out as bad as you say it is, you're gonna be wearing through 17" tires pretty fast.
