1 - 2 of 2 Posts
Both fans won't run I have checked the fuses/relays (ok) My question is, Is there a relay where the fans are? My car has a 3.2 are all the fans the same size? thanks.
no, there are relays in the power distributiion center, in th engine bay, alos is your coolant topped off with G-05 "CHRYSLER APPROVED" Coolant?, last thing to check is the ENGINE TEMP SENSOR!, its right under the upper radiator hose on the 3.2L, and 3.5L engine!, piece of cake to swap out(But first diconnect the negaitive battery pot, before swapping it out! Good Luck!
1 - 2 of 2 Posts
