1 - 20 of 23 Posts
Grab Your ***** By The Horns
2004 Dodge Intrepid Police Package
2004 Dodge Intrepid Police Interceptor
>>The Existing Mods<<
Exterior
*Black Projector Headlights H-1 35W 8000K AGT German HID's With Halos
*3000K H-3 HID Xentec Fog Lights
*Chrysler 300M Special Heated Turn Signal Mirrors
(Professionally Painted By Jake Pierson)
*LED 60-60 Diode SMT, Amber/Off (A/O) Stealth Ultimate Switchback Bulbs (Front Running Lights/Turn Signals From Autolumination)
*LED 60 Diode Rear Turn Signals, Brake Lights & Reverse Lights (From Autolumination)
*OEM Embroidered "Intrepid" Leather Car Bra
*Modified DRL Module
*Rain-X Repel Wipers
*Mopar Black Door Edge Protectors
*LED License Plate Light
*Trunk Lid Spoiler (May 2013)
*GoodYear RS-A Plus, 25R16, V Rated Tires
Interior
*LED Map Lights, Rear Overhead Courtesy Lights & Trunk Light
*EVIC Featuring TPMS & IMPG With Blue LED's
*2004 Model (ATC) Automatic Temperature Control With Blue LED's
*Auto-Dim Mirror
*LED Vanity Mirror Lights In Sun Visors
*LED Lighted Glove Box
*Lighted 1st Gen Ignition Key Ring
*Lighted Window Control Switches On Driver's Door
*Black A, B & C-Pillars
*2002 Chrysler 300M Special Dark Slate Leather Heated, Power & Memory Seats With SRS Side Airbags
*Center Console With Chrysler 300M Black Leather Lid & 2nd 12V Power Outlet Inside
*1998 Dodge Intrepid ES Black Cluster Bezel With "Pockets"
*Chrysler 300M 150 MPH Special Cluster With Dodge Intrepid EL Police Gauges Swapped On
*Chrysler 300M Special Full Dash, Body & Front Doors Harness Swap
*Black Leather Steering Wheel With Stitching
*Shift Bezel Blue LED Lighting (By Squilliam)
*Black Leather With Chrome Shifter Knob
*Dodge Ram Logo Monogrammed Floor Mats
*Trunk Lid Liner
*WeatherTech Smoked Side Window Deflectors (Front Doors)
*Operational Rear Passenger Doors
Aftermarket Audio
*Alpine iDA-X305S Head Unit (Ipod/USB/Satellite/Bluetooth Mobile Phone Ready)
*2 JL Audio Type ZR570-CSi Component Front Door Speakers & Tweeters
*2 JL Audio Type ZR570-CSi Component Rear Deck Speakers
*1 Alpine PDX F6 Amplifier
*2 Alpine Type R, SWR1243D 600W RMS 12" Subwoofers With Grill Covers In Sealed Box In Trunk
*1 Alpine PDX M12 Amplifier
*2 Exposed LHS Rear Deck Speaker Grilles
*SiriusXM Satellite Radio
Performance
*K&N Cold Air Intake 57 Series FIPK 2
*Plenum Intake Spacer (By SPAD3)
*Column Shifter To Floor Shifter With AutoStick Conversion
(Cables Installed By Daytrepper)
*R1 Concepts Premium (PHP) Cross Drilled & Slotted Rotors
*R1 Concepts Posi-Quiet Ceramic Brake Pads
>>Future Mods Wish List<<
*Projector HID Fog Lights With CCFL Halos
*LED Courtesy Lights In All Door Panels (Acquired Hardware, Uninstalled)
*Tire Pressure Sensors (TPMS) For EVIC
*Dual Exhaust System
*70MM Throttle Body Intake
*Blackened Trunk Badgeing
*Black Roof Liner
*Digital Phaze Morpher For EL Cluster (Acquired Hardware, Uninstalled)
Then:
The PoPo meets my old SE
And Now:
July 2011
K&N 57 Series FIPK2 Cold Air Intake
Sail Housings Fitted With JL Audio ZR Aftermarket Component Tweeters
Shifter Bezel LED Lighting Mod (By Squilliam)
EVIC Install With LED Map Lights
Vanity Mirrors LED Lighting Mod
ATC Control Head LED Mod
LED Turn Signals, Brake Lights & Reverse Lights
LED Trunk Lid Brake Lights
300M Leather Seats (1st Change-out)
Aftermarket Audio Install
>>100K+ Maintenance<<
*Water Pump, Timing Belt & Hydraulic Tensioner Swap 04/29/11
Column Shifter To Floor Shifter Cable/AutoStick Install By Daytrepper
This is definitely a sweet ride Fred. Very quick, sounds like a rocket at 140+ MPH :cool:
Speed is Power
Discussion Starter · #6 ·
:0 are you serious !!!!
i had gone to a pick and pull and removed one in really good condition
but like 3 or 4 ppl kept tellin me it wasnt possible due to the wiring and how it came stock
I really really wanted one , but due to them i didnt take it home :banghead:
Discussion Starter · #8 ·
Well, my car only came with regular map lights. I replaced my stock roof harness with another that was wired for the EVIC. It plugs right into same spot your stock harness plugs into in left side of dash.
Discussion Starter · #10 · (Edited)
Mod Bug!, Mod Bug!, Mod Bug!!!
so what would i need to do this myself ?
You would need a full roof harness from a 2nd Gen ('98-'04) Intrepid/300M/Concorde that has/has an EVIC, and um......... oh yeah! the EVIC unit. lol
You will also need a little patience while pulling out your non-evic stock harness slowly. You will need to undo the light fixtures over your rear doors to unplug harness and GENTLY pry down the edges of your roof liner along the sides & front to tug the harness out from rear to front (Harness is glued onto liner in various spots along the way so tug with discretion so as not to damage roof liner). Next, remove left A-pillar to follow rest of wire down to relay/fuse panel under left side dash end cap where you will unplug it.
Then start to reverse the process carefully with the new harness.
You will also need to search here in the "How-to" forums if you want more info on this process & carefully cutting your roof liner properly so that your EVIC unit will fit & snap into place like it's supposed to. Good luck and enjoy the results!
Lookin good Fred, and I know where we are going drinkin next yr when we attend "DANISLE" The bartender must have been diggin one of us, Let's see 12 black n tan's at 4.50 a piece, 14.00 bar tab??? either that or she isnt very good at math !!!! Nice meetin ya Fred keep up the good work.
Discussion Starter · #13 ·
Does the 12 Volt LED flasher relay u have mean u don't need load resistors for the turn signals?
This I am not entirely sure of. I currently don't have any resistors installed because when I did, for some reason the bulb(s) intensity was decreased significantly.
Discussion Starter · #14 ·
:rofl::highfive: Next year? How 'bout September!
Discussion Starter · #16 ·
So w/o resistors in right now, do the bulbs blink realy fast like they are about 2 go out or at normal pace?
They did when I first installed them, but replacing the factory flasher relay under the dash with a relay for LED's cured that.
Search through one of my threads regarding LED lights, there's a link for the site that sells this item. If you can't find it I'll send you the link. :talk03:
Good luck & Happy Modding!
1 - 20 of 23 Posts
