Is it possible that goes to the foglight? I don't see how it could have gotten all the way up there. My other guess is the washer fluid level sending unit plug. If you don't have the message center above the radio then there is no sending unit there anyway. That one should be plugged into the bottom of the washer fluid bottle. If that doesn't reach down that far, let me know and I'll keep checking for you, as we have two first gens, one is a 97 Intrepid 3.5, so it should be very close to yours.
Thanks for the reply. Only thing is, the foglights work and the washer fluid level thing works, as well. I'm assuming this wire has been disconnected for quite some time, but I never noticed it before. It's rather short, so it seems like whatever it should be connected to is right in that general area.
it's wiring for a temp sensor, it's in every car, and if you have an OTIS, the sensor would be connected to that harness
