Seems my heat shield has started to break off at the front and is sagging down onto my cat making for one hell of a rattle. Any chance a guy with a welder could have enough room under there to tack it back in place without dropping the exhaust system down?
you probably can go ahead and try that....im pretty sure if you can get on an angle, you could probably go for it...
i had that problem and i just bent it up a bit with a pry bar and it was ok, my other car i just ripped it out all together, probably not a good idea but it worked!
