I've got a used RB1 NAV unit that I'm pulling from my R/T. Will come with the RB1/GPS Antenna/Wiring Harness and Antenna Adapter for pre 2002 LH cars. Will have the "latest' and last AL version burned NAV disc.
The RB1 fits 2002-2004 LH cars without modifications. No wiring changes needed. Only exception is 2002 SE model Intrepids which used earlier 1998-2001 wiring.
Wiring Adapter/Radio Antenna kit included for 1998-2001 cars with the 2x 7 pin radio connectors and the radio antenna adapter. For 1998 and maybe early 1999 cars you need to Verify you have the single PCI Bus connector available. It's a single wire white connector with a purple wire with a yellow stripe. Same with Base or SE cars. The RB1 won't function completely without it.
I figure $295 shipped in the Conti-USA for the whole Enchilada!
Here's a picture for those that aren't familiar with the RB1..........
Discussion Starter #2
Also have a 6 Disc CD changer with interconnect cable available that is Plug-N-Play with this RB1 and other Chrysler/Dodge radios with CD changer controls.
I'm interested in the pre 02 adapter, if the buyer of the RB1 doesn't need it.
Sent from my H1611 using Tapatalk
Just buy one off Ebay.
