Why ONLY the avic n2?? Whats the difference in features?Avenger said:RB1 connects with the factory CD changer, and SHOULD be cheaper than the AVIC. I think if you're considering the AVIC, you should ONLY consider the N2.
I was just about to post the exact same. There's my vote.Morphy said:If you are going for a clean, OEM look in your car, get the RB1.
If you want the bigger screen, more features, have a LOT more money to spend and don't mind a big ugly screen sticking out of your dash then get the AVIC N2.
Avenger said:The N2 is a huge step up from the N1
Actually, on the N2, there is a piece of tape on the bottom, that covers a piece of the circuit. you need to remove that piece and drop a little solder in there to connect them together..I have never done it, but a good friend of mine that had the N2 did it, and he said it works like a charm!Code2medic said:u cant crack it its not like a computer per to say but you can however bypass that safety feature. its all about the wiring :OP most installers will not do it however they will tell you how to bypass it if you ask them nicely? and or course maybe it will cost you a beer or two
