That's the Windoze suXPenis (SP 2) login screen.
It says to click on an account to start, but nothing shows.
Any ideas? I don't feel like re-installing the operating system.
Ya know, I've only had that happen once... but I hit CTRL-ALT-DEL a couple of times and it brought up a log in window, I logged in, haven't had it happen since.
As I said, I've only had that happen once... hope that helps you???
try safe mode and see if the account is still there (tap F8 while starting, and select safe mode. From the same menu choose "last known good configuration", or from safe mode do a system restore (windows version, not full restore) from Start > Run> %SystemRoot%\system32\restore\rstrui.exe
Hit CTRL + ALT + DEL twice and the login screen came up.
Same thing happened when I restarted. I will run tweakUI and see what I can change.
Thanks!
EDIT :
Forgot about the system restore. :D
Will do that before I f*ck anything up.
