Hi, does anyone know what exactly needs to be done, to replace my 95 eagle vision with the rear seats from a 2002 dodge intrepid? Thank you..
I believe the brackets and framing has to be changed over as the bolt holes do not line up.
I have 94 Grey leather Corde seats in my eagle and they are nice for the job! I do have 2001 300m black leather fronts up front however.
If you want a plushy leather LHS seats work best also.
Ok just checking would pull them off tomorrow if they did.. Thanksthe 2 g shifter has a bracket for the shifter cables attached to it, the 1st gen doesn't. I don't think the 01 has a tcm, I believe they were all one unit by that point. It wouldn't work anyway.
I'd pull the shifter anyway - if I remember right there is one other difference, but the parts from a non-autostick 1st gen will retro fit the second gen autostick shifter, or something like that.
You will need a 1st gen TCM with autostick though to make it do anything though - a second gen electronics won't help, as stated above.
As was stated above me as well, yes. I seem to remember having to do some obvious and simple internal part swapping to make a few changes for complete compatibility, but I may be remembering parts I swapped to do a repair of the shifter button mechanism.So that 01 autostick shifter will work in my 96? just if i can i will slowly get the stuff for the autostick conversion. right now will be doing the Four Wheel Disk Conversion next week..
