41 - 50 of 50 Posts
I've never heard anything about an LHS unit not working. Granted they were never offered with the autostick option, which is where I think this is coming from. If you do swap to the LHS interior you will have to modify the stock center console piece as it is unique to the layout for the LHS.
Ya i saw that and was thinking that the 01 intrepid Autostick Bezel and the LHS bezel and maybe able to combined the two peaces together.. Going back to the yard and will see if it looks good to do.. Nothing like a little Fiberglass want fix...I custom my Radio Bezel to fit a 7'' tough screen in the Intrepid this should be no different....
1st Gen FTW - It's AutoMedic!
Actually, an easy mod to make the LHS into an autostick is to use a knife and some patience... Take the Intrepid autostick console, and carefully cut in the groove around the shifter area of the console, till you break all the way through. Then, on the LHS console you make the same cuts. Swap the cut parts and using the attaching method of choice, meld the two together. You could use expoxy, you could plastic weld with a soldering iron, or of course you could use the Handy Man's secret weapon, DUCT TAPE! (no, just kidding!)
Since you are cutting in the groove or seam between the shifter area and the 'textured' part of the bezel, the joint and swapping is MUCH less obvious.
I did this mod for Kyle's mother last year at Art's meet. Worked out nicely. The alternative is to cut straight across the whole console right in front of the shifter part of the bezel, but this gives you a hard line edge that is very visible. One member on the board did that a few year back, and didn't look too bad. Something to dress the cut would be nice.
I combined the two Shifter Bezel into one... Much easier then cutting the center consul
Here's the custom Autostick shifter Bezel for the 94 LHS center consul .. >>>>
Took a 01 Intrepid w/autostick and a 94 LHS Bezel >>>>
That's actually a pretty nice mod, I'd love to see how it actually looks and works in the car. Also, just a thought, but to get a more "stock" look to it, couldn't you make sure that on the back it's secured very well, and sand the whole top smooth, and get putty primer (I believe it's that or high-fill primer or something like that) and spray it with that, or better yet actual trim paint from I believe dupli-color that's already textured, then get a paint that matches the current color of the bezel and paint over it to make it look as though it came factory?
Just my randomness speaking, ya know? I believe it'd look good, Hell it already looks great, just puttin' stuff out there ya know? xD
OK I'll take the Handy Man's secret weapon >>>>
LOL Nice I hope that was just to hold it while something else dried :p
Dain bramaged
I had one, My buddy made it for me. Then the boot ripped due to it being just a tiny bit to short, so my buddy took it back to fix it. He put it in his car to test it, then sold the car with the console piece in it.
It works, it looks good. The only thing I couldn't find was a way to keep the texture consistent and a paint to match the stock "grey". I ended up sanding it smooth and just primered it. I never really got a chance to find the paint.
Ya not to worried about that seeing that my center consul matches the color of my car.. Ordered some Epoxy and will be working on it next week..
41 - 50 of 50 Posts
