Maybe something in this will help you :
Rear Wheel ABS
Disengage the rear seat lower cushion retainer loops from the cups in the floor and lift upward at each end of the rear seat lower cushion. Remove the rear seat lower cushion from the vehicle.
If equipped with a child safety seat:
Open up child safety seat and remove seat lining.
Remove mounting bolts securing the seat back frame to trunk closure panel through the access holes in the child seat module.
Remove the mounting nuts that secure the rear seat back and seat belts to the floor.
Lift the rear seat back upward to disengage the hooks at the top of the seat back and remove from vehicle.
Pull up the edge of the sound insulation on the rear bulkhead. Separate the wheel speed sensor connector from the vehicle wiring harness connector.
Carefully raise and safely support the vehicle. Remove the rear wheels.
Remove the sensor cable grommet retaining clip from the rear inner fender. Gently pull the sensor cable and grommet out of the hole in the fender well.
Remove the speed sensor head mounting bolt from the rear adapter. Remove the wheel speed sensor head from the adapter.
CAUTION
Lightly tap the edge of the sensor ear, rocking the sensor from side to side until it is free.
Remove fasteners mounting speed sensor cable mounting bracket to inner side of trailing arm.
Remove the sensor cable routing brackets from the rear fender well and trailing arm bracket at the rear knuckle.
Remove the wheel speed sensor from the vehicle.
To install:
Coat the wheel speed sensor, where it slides into the adapter, with High Temperature Multi-Purpose E.P. Grease (disc brake-rated wheel bearing grease) before installing it into the adapter.
Install the wheel speed sensor head into the adapter. Install the attaching screw and tighten to 60 inch lbs. (7 Nm).
Be sure to check the wheel speed sensor air gap clearance. The allowable clearance range is 0.017-0.047 inch (0.45-1.21mm).
Install the sensor cable mounting bracket onto the trailing arm. Install the sensor cable routing tube-to-trailing arm mounting screws.
Install the sensor cable routing brackets at the rear fender well and rear knuckle.
Install the sensor cable and grommet back into the hole in rear inner fender. Install the cable grommet retaining bracket and tighten the attaching screw.
Install the wheels and lug nuts. Tighten the wheel lug nuts in a star pattern sequence and tighten the nuts to half specification. Then repeat the lug nut tightening sequence to 95 ft. lbs. (129 Nm).
Lower the vehicle to the ground.
Attach the speed sensor cable connector to the vehicle wiring harness. Be sure that the connector locking tab is securely latched.
Install the rear seat back cushion into the vehicle in its proper position.
Engage the retainer hooks at the top of the rear seat back cushion.
Install the mounting nuts that secure the rear seat back and seat belts to the floor.
Install and tighten mounting bolts to secure seat back frame to trunk closure panel through the access holes in the child seat module.
Install the child safety seat liner.
Install the rear lower seat cushion in proper position into the vehicle.
Engage the retainer loops into cup on the floor kick-up.
To engage the retainers, be sure to push downward at each end of the lower seat cushion.
Reconnect the negative battery cable.
