Does anyone know of a site that has up todate recalls on the intrepids? I got new front tires today b/c i have an appointment at the dodge dealership to have my bushings replaced and the car aligned..... THe guy at the tire store said that they it was a recall for the intrepid with the bushings...... The dodge service guy never mention this recall, so does anyone know about this or know of a site that i can search for it.... Thanks
I forget where I saw that - others here will know. I know autozone(online) will tell you some of them if you enter you year make etc
It was alldata.com. This is what you can get for free. Don't know if it helps or not. It was for a 01 intrepid with a 2.7L. Maybe #33 is it
TSB Number Issue Date TSB Title
  1. 23-013-04 MAY 04 Interior - Front Door Handle or Bezel Replacement
  2. 24-002-04 MAR 04 A/C - Poor Performance/Erratic Operation
  3. 21-004-04 MAR 04 A/T - ATF Usage List
  4. 23-028-03 NOV 03 Body - Windows Creak/Shudder/Chatter When Closing
  5. 22-004-03 SEP 03 Wheels - Chrome Wheel Care
  6. 21-009-03 AUG 03 A/T - Diagnostic Teardown Procedure
  7. 19-005-03 AUG 03 Steering - Power Steering Fluid Usage
  8. 23-019-03 JUL 03 Body - Window Molding Discoloration
  9. 08-022-03 JUL 03 Instruments - Brightness Changes in Illumination
  10. 24-003-03 MAY 03 A/C - System Sealer Usage Prohibition
  11. 23-011-03 MAY 03 Interior - Headliner Sags/Rattles at Rear
  12. 18-008-03 MAR 03 Engine Controls - Co-Pilot Support/Cable Selection
  13. 14-001-03 JAN 03 Fuel System - Fuel Tank Slow to Fill
  14. 23-002-03 JAN 03 Body - Wind Noise From Sunroof or B-Pillar Area
  15. 02-001-03 JAN 03 Suspension - Rear Strut Squeaking Sound
  16. 24-009-02 OCT 02 A/C - System Leak Detection
  17. 25-001-02A SEP 02 EVAP System - MIL ON/DTC's Set (EVAP)
  18. 23-028-02 JUN 02 Body - Power Sun Roof Inoperative
  19. 18-020-02 JUN 02 Engine Controls - Flash Reprogramming Failure
  20. 23-015-02 APR 02 Outside Rearview Mirror - Glass Replacement
  21. 08-007-02 MAR 02 Keyless Entry - Programming Procedure
  22. 09-001-02 FEB 02 Cylinder Head - Oil Gallery Cup Plug Service
  23. 07-002-02 FEB 02 A/C - Low or No Cabin Heat/Engine Overheat
  24. 08-025-01 NOV 01 Air Bag - On/Off Switches
  25. 19-009-01 OCT 01 Driver Airbag - Trim Cover Service
  26. 21-010-01 OCT 01 A/T - 41TE/42LE Torque Converter Clutch Break-In
  27. 23-019-01 AUG 01 Power Seat - Moves Fore and Aft Slightly When Driving
  28. 08-010-01 MAY 01 Airbag/Clock Spring - Service
  29. 18-012-01 MAY 01 Generic Scan Tool - Reference Information
  30. 09-003-01 MAY 01 Engine Oil - Additives/Supplements
  31. 08-007-01 APR 01 Instruments - Fuel Gauge Drops to `E'
  32. 18-009-01 MAR 01 EVAP System - Leak Detection Pump Operation
  33. 19-001-01 MAR 01 Steering - Loose Feel/Clunking on Turns
  34. 18-007-01 FEB 01 A/T - Surge/Sag/Shift Bump
  35. 23-003-01 FEB 01 FMVSS201 - Head Impact Safety Standards
  36. 08-042-00 DEC 00 Keyless Entry - Remote Identification & Programming
  37. 02-008-00 DEC 00 Steering/Suspension - Lead or Pull Diagnosis
  38. 08-038-00 DEC 00 Restraint Systems - Service Precautions
  39. 26-012-00B DEC 00 Electrical - Wiring Diagram Updates
  40. 08-033-00 NOV 00 Sound System - ``Cold CD'' Fault Code Information
  41. 23-039-00 OCT 00 Door Glass Lift Plate - Service
  42. 08-031-00 OCT 00 Window - Sticks in The Up Position
  43. 23-29-00 JUL 00 Rear Door Trim Panel - Loose At Upper Rear Corners
........and remember the difference between a recall and a tsb
A recall is a mandatory repair whose cost is paid for by the car mfgr,
A TSB is a diagnosis & repair guide for a common problem.
LHSDriver01 said:
Dodge's website has a utility where you can enter your vin and see what recalls are still open on your car.
Here are your results
VIN Number:
(They only asked for the last 7 characters) YH342701 Vehicle Description:
DODGE INTREPID FOUR-DOOR SEDAN Model Year:
2000
No Incomplete Recalls or Customer Satisfaction Notifications Exist
Thanks for the link LHSDriver01!! :)
