So i dont think my A/C is as cold as it should be so i went out and bought one of those universal R-134a cans..so i could recharge my system..
The first thing you are supposed to do is measure your system and see if you need to refill it..
the can says..0-25 refill system
26-40 system fine
41-65 system overfilled seek professional help
well i was in the70 range
SO I THINK I HAVE A PROBLEM
any ideas guys?
Thats definitely higher than it should be. Did you connect it to the low side and was the car running with the A/C on? If not, you may have gotten an inaccurate reading. If you're running at 70 on the low side then you definitely don't need to add refrigerant and you should take it to a shop to get it looked at because there is something wrong.
D'oh i didnt test it with the car running..im an idiot..thanks for the help
lol whoops
