· Registered
I have a small problem with my Keyless Entry. I can not seem to get the driver side door to unlock but all the other do unlock and I keep setting off my alarm and getting stared at in the parking lot. Like I don't know how to use my car. I tried switching remotes and that didn't help. I don't know much about how this system works so I am open for any suggestions or ideas.
Please help so I don't keep looking like an ass :confused:
· Registered
Stock Keyless or Did u have some place add it in??
If it was added, bring it to the place and complain, they will fix it, if it was stock, I believe theres a fuse, check to make sure its not blown, I added my own keyless/remote start, the keyless was a bizatch cause of the dimming effect that intrepids have each door is seperate which is a ***** ( pardon my language but it is ) cause you have to get the wires, but check fuses first, if not the fuse, then I hope someone else here knows...
I tried
Spyder :D :D
· Registered
The actuator in the drivers door lock went. I had the same happen to my car. I went to the junk yard near me and pulled it from another Intrepid and it worked fine. Using the Haynes manual made life alot easier pulling the door off.
· Registered
Its real simple. Take the screw out of the grab handle for the door, the lever to open the door and the screws on the edge. Then just lift up on the whole door panel and it comes out just be careful with the wiring for the locks, speakers, etc.
