I've just put everything back together, the horn works, airbag light goes off, cruise control will not activate now though? I've checked the manual looking for a fuse specific to cruise control, I can't find anything.
Disconnecting at the jump point up on the passenger fender is what's typically done. No reason to get down into the battery compartment ...Regarding disconnecting the battery cable, is disconnecting the negative cable at the jump point ok or does it need to be done at the battery itself?
See I noticed my cruise control isn't working after I seen my Air bag light was on and also found out my horn wasn't working either. I asked in another thread concerning the air bag light and horn issue whether the cruise control was going through the clockspring or not.The cruise control connectors now come from the steering wheel wiring instead of directly from the clockspring.
So, why don't we just use the clips from the old wheel??? I bought an '02 wood grain steering wheel for my '99 300M. Can't I just use the clips that came with my steering wheel and NOT the newer ones???WARNING: Airbag clips for 2003-2004 (and maybe late 2002) are different than earlier models and these are not interchangeable
Using newer clips on an older model airbag may result in intermittent contact while driving
you can ... good buy thoughSo, why don't we just use the clips from the old wheel??? I bought an '02 wood grain steering wheel for my '99 300M. Can't I just use the clips that came with my steering wheel and NOT the newer ones???
