Anyone know how to remove the fuel rail from the fuel line in back of a (2-Gen) 3.2/5L H.O.? I know there is a disconnect fitting there where the 2 lines meet, but I have never removed fitting like this, looks like plastic, are these replacable?, or have to be discarded once opened?, or they can be re-used?, I looked in the haynesmanual, and FSM, with out any extra luck, any help will be greatly appreciated! guys/gals, ;)
Thanks!
Luroc
They do not need to be replaced once removed. It sucks if you break them. They are part of the main line to the tank. To take it apart, just press the two green plastic tabs on the line and pull gently. There is one on each side. Dont force it.
