1 - 1 of 1 Posts
Here's a quick guide to help you remove your lights in order to change the bulbs or for some custom work
here is a pic showing the retainers to be removed to pull the side tail lights, just remove all three bolts and the entire light will pull out giving you easy access to the bulbs
next is the center bar (3rd brake light bar), if your car has a trunk liner you must first remove this by pulling out the small black retainers, now you can see the two brake bulbs circled in green
if you wish to remove the entire bar it is held in by the four red circled retainers, just unscrew these and the entire bar pulls right out
1 - 1 of 1 Posts
