1 - 2 of 2 Posts
Is there a reason, other than purely cosmetic, to remove them? I have a heat gun (900 degrees), so heating them for removal would not be an issue...just don't want to mess up my car, you know? And, can someone give a step-by-step on how to remove them safely?
Not sure about the DING GUARDS, however I'd had nothing but success using an ordinary hair dryer.
A heat gun at 900 degrees, if applied inappropriately, risks scorching or bubbling and then you're SOL.
I recommend a regular hair dryer and that you take your time, wear gloves so you don't burn your fingers or use a RESIN putty scraper as a metal one will scratch ...
patience is the answer here. GOOD LUCK!
1 - 2 of 2 Posts
