A limb fell on the tail light panel of my Intrepid and cracked it. I did not see any access from underneath the truck to remove it. It appears to be glued on. How is it removed?
Will rain getting in it cause any problems until I can replace it?
It has plastic wing nuts holding it on inside the trunk. If the inside of the trunk lid is covered with the gray felt material you'll need to remove some of the round button plastic retainers to drop the cover. Then you can access the light bar retainers from inside the trunk lid.
There are at least four black plastic nuts on the inside of the trunk lid. Use a 10mm or 11mm socket.
Undo the nuts and remove the two bulbs and it should come off with a little wiggling.
It can fill with water and leak into the trunk,
