1 - 20 of 43 Posts
I've had Powerstop cross drilled and slotted. Warped within a year.
I've now had 2 full sets of of R-1 concepts (cross drilled/slotted) and the front's are warped in in record time. Nine months! This is with their brand of ceramic pads to boot. The back are in good shape, but still.
Brakes were bled and the break in procedures were followed. I have no hanging/frozen calipers. I'm just stumped. I've owned six Dodge vehicles over the years (this being #7) and I've never had a car eat rotors like this before.
Thoughts?
NAPA Performance Rotors FTW!
I second that. Ive had napa United Parts rotors on my car going on 6 years now. No warp, never have needed to be turned. They are just the regular ones, but still.
Bendix. A bit pricey but worth it. I bought their standard ones for my car. Not much use. But have seen and been in cars with their rotors that have been heavily abused. Not one pulse in the pedal.
Had R1 ecolines rotors for 4 1\2 years on front, and rear. And the current set of 300m PHP R1 rotors going on 2 years with no issues on the front.
Not to mention both sets saw autocross and very spirited driving.
I don't know why your have warped like that have unless it was bad run or something else is going on.
My guess is that the rotors aren't the problem - that the problem is pads with "gummy" binders that unevenly film the rotors mimicking warped rotors. I used to have problems with what I thought were warped rotors. No matter what I tried, the brakes still pulsed. When I finaly realized that the pads were the cause and attacked *them* instead of the rotors, my braking problems disappeared (the break-thru for me came when an engineer at Frozen Rotors talked me into quitting using ceramic pads).
get off my lawn
go with the Napa's,, forget the drilled and slotted stuff,, it just weakens the rotor,,
Those would be the NAPA Premium Rotors instead of the Performance Rotors that I pictured. I had a pair of NAPA Premiums on the 2002 R/T which worked fine for over two years.
I've also had good luck with the NAPA premium rotors, followed by the Bendix. Although availabilty has been an issue with the Bendix.
I've been running Wearever rotors for a while now (6 years) and so far no issues. Bought those from Advance Auto.
I tend to agree with PEVA on the pads being a problem on it .
There's also the NAPA Ultra Premium rotors (86777), which are painted (and may be one notch better as far as materials and processing - how do you know?) which aren't drilled or slotted.
Be aware that NAPA rotors are reboxed Raybestos - so you can use that fact for price shopping the same exact rotors. (NAPA Ultra Premium 8677 are Raybestos 76777). Also, consider the Centric 12063048 competing rotor. Rock Auto has Raybestos and Centric.
I have never liked Centric. I worked at a shop that loved to sell them to customers. They all sucked. For one, not one was even close to being true to shape or centered. Majority of them had to be re-cut out of the box before being bolted on the car or they would shake and/or pulse. Quite a few came back around 1,000 miles with center ribs splitting. They were okay or bad, but too much chance of bad IMHO.
Same problem.....
I have endless trouble with front only
Factory rotors, warped first couple years
Power slot rotors lasted longer, warped, and hawk ceramic pads gave no stopping power unless they were HOT- very bad!
Now have Raybestos rotors and pads, tons of dust, and squeak like he'll! But no warp yet.
But that's over 10 years and 100 000 miles, and my only major recurring problem with this car.
ceramic pads are better but work alot hotter causing your warping.
i found the same thing. my rotors need machineing once or twice a year.
ceramic pads are better but work alot hotter causing your warping...
For a given stop (i..e, energy dissipated), the same amount of heat is generated. From what you're saying, ceramics (if you can generalize) don't conduct the heat away from/out of the rotor as well as other materials. That's an argument not to use ceramics in my book.
It's been hard for me to find a decent set of rotors/pads in Canada.
I've always gone with Wagner premium gear (PHP) and since they outsourced the crap to china ive not been lucky, only a year on the rotors and pads, and they shudder like crazy. The w clips have melted on the passenger side and the brake noise/dust is unbearable.
I want to get into buffalo and buy some quality made parts from the USA, seems like NAPA is the way to go (they are supremely expensive in Canada).
The Womanizer!
Ive had the R1 rotors all the way around for probably 4 years, no problems at all
I've used the PHP center vented rotors from Advance Auto (YH145263) for over 5 years, no issues.
i was MAJORLY generalizing.......:talk01:
my understanding is that they are capable of running at alot hotter temperatures, and the hotter they get the better they work, causing more friction and yet getting hotter....????
when i tried a set of 14.99 "cheapie" pads to test my rotor warp i found they didnt warp nearly as fast. by no means scientific though.
Farticcus of Plenticcus
Wearever Rotors from AAP FTW.
1 - 20 of 43 Posts
