21 - 22 of 22 Posts
Almost any cam shaft sensor can be tested with a digital volt meter. With a couple of stick pins you can do the test at the PCM plug. (Testing the circuit) If you are not familiar with the procedure search YouTube for "cam sensor test". Almost all of them (regardless of manufacture) work the same.
21 - 22 of 22 Posts
