1 - 20 of 20 Posts
So how many people use the Shell Rotella oil? And what type and weight are you using?
I use 15w40 in the GTX with a zinc additive, not in any other cars.
get off my lawn
im sorry,, I dont own a diesel
After reading Peva's write up, I switched to Rotella T-6, 5w -40w..
I did this on my intrepid for one oil change. I got a slightly longer tick at startup than I was use to so I switched back.
I didn't see it, anyone have a link?
Thanks
Rotella is a good oil, I use the none synthetic version for my flat lifters in the GTX, I could use synthetic as well but it's not worth it to me, I change the oil twice a year on this car and only put 3000-4000 miles on it.
On the drivers I still use what's on sale and change it at 3000, it's working for me on all my high mileage cars and I can do an oil change for around $16-$18
1st Gen FTW - It's AutoMedic!
Just to chime in with my experience... I'm using Shell Rotella T6 5w40 currently, 1 gallon, with two quarts Rotella 15w40 (6 quarts were needed, and I didn't want to buy a second full gallon of t6)...
And now for short runs, my car is fine, makes no noise... but after a decent drive (20 miles or so?) it begins to hammer a bit - really quiet, but you can hear it at idle...
I'll be dropping the oil here soon in favor for something else (likely Valvoline Dino, 5w30) and a filter change - I think I'll take some of the oil from the filter and send it to Blackstone.
Honestly the only way to tell rather or not your oil, or oil additives are doing anything is with solid proof. Using any oil analyst company would help. Say for instance I use Mobil Clean5k 10w30. I use to do 4 qts of it with one qt of lucas oil stuff. Blackstone noted my wear was great, and my viscosity was little high due to the lucas. I also noticed that molybdenum, an anti-wear agent in oil was high. So for 4 oil changes I stopped using lucas. The last report showed a jump in bearing wear, nothing critical but also showed my moly levels almost flatline compared to the old readings. So I put lucas back in and once this oil run is done back to blackstone to see if the lucas is indeed helping with bearing wear.
Discussion Starter #13
I think I'll pass on the "Craptella" oil. Thanks for the responses though.
Rotella is not really meant for gasoline engines--although many still use it for gas burners. It is used very commonly in light to heavy duty diesels, and is formulated for diesels. It is the only oil we stock at work (heavy duty truck shop)....it is most definitely not "craptella" IMO. Some of the insanely complicated V8 Ford diesels use a lighter weight than 15w40...to keep them from exploding...LOL...
I used it in both dodge Rams, one for 100K miles, the other for 200+K miles, both engines were clean as a whistle inside. It is excellent at keeping the sulphur and soot deposits from the diesel fuel from sticking to the internals. The old red 93 dodge, now with 390K miles, is still kicking strong on Rotella, we've ran it since 1997 when we bought the truck---which is now my dad's.
This is under the valve cover on my white 99 Ram, after ~50K of Rotella...this is with about 240K on the engine:
As far as gas burners, I have always been a firm believer in Mobil 1 5w30, with a Mopar oil filter, used it since zero miles on my intrepid's engine, and it has had great results. No abnormal wear on oil analysis, and the engine has remained clean enough to eat off of inside. Like Devan says, go off of proven results.
The only gas burner I ran Rotella in was my old 85 F150, with the straight 6, it quieted it down a bit, raised the oil pressure.
Discussion Starter #16
Just not going to use it. Sounds like it was a "Fad" for a few people. If it's not significantly cheaper than conventional synthetic I see no reason to use it. I don't have a 2.7L so I see no issues with sludge reduction, etc.
Dan....would you use Rotella in the SRT-8? I doubt it and I'm really not interested in using it in my other two 3.5L equipped cars now.
Again...thanks for the input that everyone provided.
I have NOT had good luck at all with any kind of Valvoline. I'm currently burning some of that new recycled Valvoline. The burnoff has finally stabilized after adding 2 quarts of Shell 10w30.
The best luck I've had has been with Castrol...although the high-mileage stuff in the green bottle burned off quite a bit, but stabilized quite quickly.
I wouldnt use it. If you drop a Cummins in one of your LH's, then yes. LOL.
No, I will not use Rotella in the Mag. Planning Mobil 1 0w-40 per the factory, with a Mopar filter when it comes due.
Consequently I ran 6 quarts of NAPA Dino 5w30 with a 1515 NAPA (Wix) filter.
Interesting thread.....never thought of using it in the ol' 3.5, just noisy at start-up with only 80,000 miles on it : /
I do however use Rotella in my 87 Shelby Charger. Seems to hold better heat properties for the turbo. The place I bought my rebuilt Garrett from recommended it rather than synthetic. I guess it has something to do with the old flat tappet slider cam and turbo combo .
So i use 15w-40 and a zinc additive...all seems well in that application.
1 - 20 of 20 Posts
