Well today I've done the most I've ever done with taking apart an engine... haha... Took off the valve covers. Well, their is some sludge build up but its not horrible. My pops said he's seen worse. He also said that the cam lobes are worn but not worn out... all my spark plugs look good except one, which might be just a bad coil pack hopefully... cause yeah, the car does have 99k on it so...
he also said the chain appeared to be in good condition, not worn down etc. I mentioned in a prior post if anyones been following thats reading this that my last oil change the oil was kinda watery (some say probably contributed to waterpump freezing up etc.) well we drained the radiator and coolant and it was nice an green, no oil. So theres no oil in the antifreeze.... not sure exactly waht that means but I got my pops helpin me or at least tellin me what to do along the way... so i take yall advice and he oversees me... im a mechanic in the making! lol... jk..
Original thread: Midas Says I Need a New Engine
Check the pics:
Right Side Valve Cover Inside:
Left Side Valve Cover Inside:
The pictures of the cam shafts are too big to post in this message so I made links to them below, I made em that way so you guys could see the sludge build up. The right side is worse then the left. But do you think I can do the timing chain kit with waterpump and get back and forth to work for a few more months or so? Like I've been saying... I'm trying to buy time to save for a 3.2L or 3.5L plus conversion kit etc.... I'm dropping the oil pan tomorrow so I'll have pictures of that as well... Thanks!
Right side cam shaft etc. 1.3 Mb
Left side cam shaft etc. 1.1 Mb
Both cam shafts 1.4 Mb
UPDATE:
Ok got the harmonic balancer off and cover. I posted some pics below. Man my moms boyfriend did lie to me! He said he got out as many parts as he could?! Well I was looking right into the oil pan after I drained it (pics are before drain) and theres tons of little debris and parts of the little side tensioner that originally snapped... What does that tell me? He didn't even drop the oil pan!!! Whata buster... anyway... I got the oil pan all unhooked but no mater how much I manuevered it it just couldnt get through... I think the cars jacked up too high and the bottom bar is whats in the way... I'm gonna drop the car tomorrow and that should move that bar and give me clearence... cause seriously... I got the front of the car on jackstands and.... that oil pan will not get through no matter what... its stuck on the front frame and back bar. I think its the stabalizer bar...
You can see how LOOSE the timing chain is... It must have jumped? Plus you can see the groves in the waterpump... the one you can see is the worst. The other side of the waterpump is not bad and the oil pump has some chipped away as well... i think thats what my moms boyfriend (that works at midas) was talking about for filings being in the engine? anyway... What do ya think?!
UPDATE 2:
I got the oil pan off and there were lots of little debris from the small tensioner that broke. Well I looked in the oil screen return and that was almost full of crap too. Heres a pic:
Now... I'm getting confused because so many people keep saying flush with this and that... anyhow... what should I use to flush through the return screen and what should I use to clean out the oil pan? I have a compressor in the garage so I was thinking maybe water and compress it dry really good... but I dunno... what do you think?
Also I forgot to take pictures but the timing chain does look like it jumped a tooth. My pops lined up all the marks and he said that from the feel of it it doesnt feel like the valves got bent at all. He said you'd be able to tell when turning it, something about it hiting a piston and being very difficult to turn? (i dunno). Also he said that usually it takes jumping a few teeth for valves to bend... hopefully thats correct. So yeah, the timnig chain was off mark by one link/tooth...
Now my last question... I'm looking at the valves and I'm finding more and more little debris here and there... I was thinking of pouring oil on it and the timing chain but I already got the front cover off so oil would pour everywhere I think... any suggestions? I was thinking of using a shop vac and trying to suck up as much as I could see, sound like a plan or what?
Thanks for all the help in advance...
UPDATE 3:
(nevermind just flushed it with water... figure it'll have like 2 weeks to dry before i put in the timing chain etc anyway... plus ill run the air compressor on it really good...)
Check the pics:
UPDATE:
UPDATE 2:
UPDATE 3:
