1 - 11 of 11 Posts
Hi,
I have a 99 Intrepid 2.7L which has a small (few drops) anti-freeze leak at a fitting on top of the upper radiator hose. The fitting is similiar to a grease zerk. Does anyone know what this fitting is for and why the leak? If this is a regular zerk it should be a spring loaded ball and should seal. If it is a regular zerk it should be easy enough to replace. Thanks for any comments and suggestions. I am off to try to remove my battery - I enjoy a challenge.
On the 1st Gen, this fitting us used to bleed air from the cooling system when you do a flush/fill of the coolant. That housing also holds the thermostat.
Hope this helps...
Cheddar
with the car cool, try to put a wrench on it, and see if you can close it. you may have to open it and and close it again.
Thanks to everyone for your help and comments. Sometimes I get lost under the hood on a newer and considerably more expensive car than I have worked on in the past
Hey, I found this on EBay if it keeps leaking: Plan B
Thanks - I tried loosening the fitting. No leaking immediately when running, then after sitting overnight leaked again. Is this fitting like a zerk and can be independently replaced?
I'd take it right out and have a close look at the end. There may be a rough spot you can file for a better seal, or a bit of dirt in there.
nope. It usually leaks between the plastic and the metal ring, not at the threaded bleeder valve. Tighten a hose clamp around the black plastic ring on the top and that should fix it. Otherwise you have to replace the bleeder housing which is not that easy to do. Search the site for "bleeder housing" and you'll find plenty of posts.
Thanks for the information. This leak is at the top of the bleeder valve or at least it is the most visible leak coming out the top of the valve. I haven't found any other leaks furthur down
Discussion Starter #11
I did find a listing for the bleed valve in a parts book, so if the clamp doesn't work, I will pursue replacing the valve
1 - 11 of 11 Posts
