4000? I would first be looking for another mechanic. what a rip off. the engine itself is probably $1000 max and labour can only be $100/h at max.. the job is only 12 hours. $4000 ... wow.. what a crazy ripoff that is. Granted they're not identicle, but my I removed and replaced the engine in my first gen (red) in 10 hours. I cannot see how $4000 is justified.My car is a 2000 Dodge Intrepid, V6 2.7L. mileage: 146000,
I drived it without engine oil check, so my engine is gone.
I bought this car for 4000, and now replace a engine cost me 4000,
What should I do?
depending on where he is in the world, 2.7l replacement motors are very expensive for rebuilt units. i've seen 1200-2400 per engine.4000? I would first be looking for another mechanic. what a rip off. the engine itself is probably $1000 max and labour can only be $100/h at max.. the job is only 12 hours. $4000 ... wow.. what a crazy ripoff that is. Granted they're not identicle, but my I removed and replaced the engine in my first gen (red) in 10 hours. I cannot see how $4000 is justified.
where are you located?My car is a 2000 Dodge Intrepid, V6 2.7L. mileage: 146000,
What should I do?
2400.. ripoff. unless it had 20,000kms on it, that is a complete rip. the dealer charges 4000 for a *new 2.7 installed..depending on where he is in the world, 2.7l replacement motors are very expensive for rebuilt units. i've seen 1200-2400 per engine.
I can set you up with a guy that will, and he is good, I'd verify his work.I'm in the same boat, anyone around Newtown, PA to do a 2.7 to 3.5 conversion?
