General Specifications:
Vehicle - Front engine, front wheel drive, 5-6 passenger, 4 door sedan
Wheelbase - 113.0 in.
Length - 201.6 to 201.8 in.
Width (at mirror tips) - 80.5 in.
Track - 62.0 in.
Turning diameter - 37.7 ft.
Curb weight - 3,400-3,550 lbs.
Transmission - 42LE four speed automatic
3.3L V6:
Type - OHV 12 valve
Fuel Delivery - Sequential Multi-Point Fuel Injection
Fuel Requirement - 87 octane unleaded
Net Power (1993) - 153 bhp @ 4800 rpm
Net Torque (1993) - 177 ft/lbs @ 3200 rpm
Net Power (1994+) - 161 bhp @ 5300 rpm
Net Torque (1994+) - 181 ft/lbs @ 3200 rpm
Bore and Stroke (in.) - 3.66 x 3.19
EPA Fuel Economy (city/hwy.) - 20/28
Acceleration 0-60 m.p.h. - 10.3 sec.
3.5L v6:
Type - SOHC 24 valve
Fuel Requirement - 89 octane unleaded
Net Power (1993-1995) - 214 bhp @ 5800 rpm
Net Torque (1993-1995) - 221 ft/lbs @ 2800 rpm
Net Power (1996-1997) - 214 bhp @ 5850 rpm
Net Torque (1996-1997) - 221ft/lbs @ 3100 rpm
Bore and Stroke (in.) - 3.78 x 3.19
EPA Fuel Economy - 18/26
Acceleration 0-60 m.p.h. - 8.7 sec.
8.3 sec. w/Perf. & Handling Pkg.
Source: allpar.com
3.5L Engine Specifications:
GENERAL ENGINE SPECIFICATIONS
GENERAL SPECIFICATIONS TABLE
Application Specification
Displacement .......................... 215 Cu. In. (3.5L)
Bore ....................................... 3.78" (96 mm)
Stroke .................................... 3.189" (81 mm)
Compression Ratio ................................ 10.45:1
Fuel System .......................................... SFI
Horsepower @ RPM .............................. 214 @ 5800
Torque Ft. Lbs. @ RPM ......................... 221 @ 2800
CRANKSHAFT, MAIN & CONNECTING ROD BEARINGS SPECIFICATIONS
CRANKSHAFT, MAIN & CONNECTING ROD BEARINGS TABLE
Application In. (mm)
Crankshaft
End Play ........................... .004-.012 (.10-.30)
3.5L V6 - VIN [F] Article Text (p. 21)
Runout ................................... .00012 (.003)
Main Bearings
Journal Diameter ........... 2.519-2.520 (63.987-64.013)
Journal Out-Of-Round ..................... .00012 (.003)
Journal Taper ........................... .00022 (.0057)
Oil Clearance .................. .0004-.0020 (.010-.050)
Connecting Rod Bearings
Journal Diameter ........... 2.283-2.284 (57.979-58.005)
Oil Clearance ................ .00075-.00340 (.019-.087)
CONNECTING RODS SPECIFICATIONS
CONNECTING RODS TABLE
Pin Bore Diameter .......... .9452-.9455 (24.0076-24.0153)
Side Play .................................... .0157 (.40)
PISTONS, PINS & RINGS SPECIFICATIONS
PISTONS, PINS & RINGS TABLE
Pistons
Clearance .................... .00075-.00200 (.019-.050)
Diameter ..................... 3.77-3.78 (95.956-95.974)
Pins
Diameter ................... .9448-.9449 (23.997-24.000)
Piston Fit ..................... .0002-.0006 (.005-.015)
Rod Fit ........................ .0003-.0007 (.007-.019)
Rings
No. 1
End Gap .......................... .012-.018 (.30-.46)
Side Clearance ............... .0012-.0031 (.030-.080)
No. 2
End Gap .......................... .012-.022 (.30-.55)
No. 3 (Oil)
End Gap .......................... .010-.030 (.25-.75)
Side Clearance ............... .0019-.0077 (.047-.196)
CYLINDER BLOCK SPECIFICATIONS
CYLINDER BLOCK TABLE
3.5L V6 - VIN [F] Article Text (p. 22)
Cylinder Bore
Standard Diameter ............................ 3.78 (96)
Maximum Taper .............................. .002 (.050)
Maximum Out-Of-Round ....................... .003 (.076)
VALVES & VALVE SPRINGS SPECIFICATIONS
VALVES & VALVE SPRINGS TABLE
Intake Valves
Face Angle ......................................... 45ø
Head Diameter .......... 1.3728-1.3831" (34.87-35.13 mm)
Minimum Margin ............. .0402-.0531" (1.02-1.35 mm)
Length ............... 4.5043-4.5272" (114.41-114.99 mm)
Stem Diameter ............ .2730-.2737" (6.935-6.953 mm)
Exhaust Valves
Head Diameter .......... 1.1366-1.1468" (28.87-29.13 mm)
Minimum Margin ............. .0567-.0697" (1.44-1.77 mm)
Length ............... 4.9476-4.9705" (125.67-126.25 mm)
Stem Diameter ............ .2719-.2726" (6.906-6.924 mm)
Valve Springs
Free Length
Intake ............................ 1.7811" (45.24 mm)
Exhaust ........................... 1.7992" (45.70 mm)
Installed Height ....................... 1.4961" (38 mm)
Pressure (1)
Valve Closed
Intake ..... 90.4-99.8 @ 1.4961 (40.99-45.27 @ 38.0)
Exhaust .... 80.7-89.2 @ 1.4961 (36.61-40.48 @ 38.0)
Valve Open
Intake .. 201.8-218.5 @ 1.1752 (91.57-99.11 @ 29.85)
Exhaust .. 158.5-171.5 @ 1.239 (71.89-77.80 @ 31.47)
CYLINDER HEAD SPECIFICATIONS
CYLINDER HEAD TABLE
Maximum Warpage ........................... .008" (.20 mm)
Valve Seats
Seat Angle ......................................... 45ø
Seat Width ................. .0492-.0689" (1.25-1.75 mm)
Maximum Seat Runout .................... .002" (.050 mm)
Valve Guides
Intake Valve
Valve Guide I.D. ..... .25885-.27560" (6.575-7.000 mm)
Valve Guide Installed
Height ................... .3740-.4134" (9.5-10.5 mm)
Valve Stem-To-Guide
Oil Clearance ......... .00090-.00256" (.022-.065 mm)
Exhaust Valve
Valve Stem-To-Guide
Oil Clearance ........... .0020-.0037" (.050-.094 mm)
CAMSHAFT SPECIFICATIONS
CAMSHAFT TABLE
Bore Diameter .............. 1.6944-1.6952 (43.038-43.059)
End Play ............................. .004-.014 (.10-.35)
Journal Diameter ........... 1.6905-1.6913 (42.939-42.960)
Journal Runout ............................. .00012 (.003)
Lobe Lift
Intake .................................... .3209 (8.15)
Exhaust ................................... .2571 (6.53)
Oil Clearance .................... .0031-.0047 (.078-.120)
Source: 1998 Mitchell Repair Manual (1994 Intrepid)
3.3L Engine Specifications:
Displacement .......................... 201 Cu. In. (3.3L)
Bore ..................................... 3.66" (93.0 mm)
Stroke ................................... 3.19" (81.0 mm)
Compression Ratio .................................. 8.9:1
Horsepower @ RPM .............................. 161 @ 5300
Torque Ft. Lbs. @ RPM ......................... 181 @ 3200
Crankshaft End Play ................ (1) .004-.012 (.1-.3)
Main Bearings
Journal Diameter ......................... 2.519 (64.00)
3.3L V6 - VIN [T] Article Text (p. 19)
Journal Out-Of-Round ........................ .001 (.03)
Journal Taper ............................... .001 (.03)
Oil Clearance .................. .0007-.0030 (.018-.076)
Journal Diameter ......................... 2.283 (58.00)
(1) - Wear limit is .010" (.25 mm).
Side Play ............................ .005-.015 (.13-.38)
Pistons
Clearance ...................... .0010-.0022 (.025-.057)
Diameter ................. 3.6594-3.6602 (92.950-92.968)
Pins
Diameter .................................. .901 (22.88)
Piston Fit ..................... .0002-.0007 (.005-.018)
Rod Fit ............................................ (1)
Rings
No. 1 & 2
End Gap .................. (2) .0118-.0217 (.300-.550)
Side Clearance ........... (3) .0012-.0037 (.030-.095)
No. 3 (Oil)
End Gap ..................... .0098-.0394 (.250-1.000)
Side Clearance ............... .0005-.0089 (.014-.226)
(1) - Interference fit.
(2) - Wear limit is .039" (.99 mm).
(3) - Wear limit is .004" (.10 mm).
3.3L V6 - VIN [T] Article Text (p. 20)
Cylinder Bore
Standard Diameter .......................... 3.66 (93.0)
Maximum Taper ............................... .002 (.05)
Maximum Out-Of-Round ........................ .003 (.08)
Intake Valves
Head Diameter .......................... 1.79" (45.5 mm)
Minimum Margin .......................... .031" (.79 mm)
Minimum Refinish Length ............. 4.936" (125.38 mm)
Stem Diameter ........................ .3124" (7.935 mm)
Exhaust Valves
Head Diameter ........................ 1.476" (37.50 mm)
Minimum Margin ......................... .047" (1.19 mm)
Minimum Refinish Length ............. 4.961" (126.00 mm)
Stem Diameter ........................ .3112" (7.904 mm)
Valve Springs
Free Length (Approximate) ............ 1.909" (48.50 mm)
Installed Height ......... 1.539-1.598" (39.10-40.60 mm)
Pressure (1)
Valve Closed .............. 95-100 @ 1.57 (43-45 @ 40)
Valve Open .............. 203-224 @ 1.18 (92-104 @ 30)
CYLINDER HEAD TABLE
Maximum Warpage .. (1) .00075" Per 1" (.0190 mm Per 25 mm)
Valve Seats
Intake Valve
Seat Angle ....................................... 45ø
Seat Width ................. .069-.088" (1.75-2.25 mm)
Maximum Seat Runout ................... .003" (.08 mm)
Exhaust Valve
Seat Width ................. .057-.078" (1.50-2.00 mm)
Valve Guides
Intake Valve
Valve Guide I.D. ....... .3130-.3149" (7.950-8.000 mm)
3.3L V6 - VIN [T] Article Text (p. 21)
Valve Stem-To-Guide
Oil Clearance ........... (2) .001-.003" (.03-.08 mm)
Exhaust Valve
Valve Stem-To-Guide
Oil Clearance ........... (3) .001-.003" (.03-.08 mm)
(1) - Maximum combined total grind limit of cylinder head
and cylinder block is .008" (.20 mm).
(2) - Wear limit is .0097" (.247 mm), measured with dial
indicator at valve head with valve .55" (14.0 mm) off
its seat.
(3) - Wear limit is .016" (.41 mm), measured with dial
its seat.
CAMSHAFT SPECIFICATIONS TABLE
End Play ............................. .005-.012 (.13-.30)
Journal Diameter
No. 1 ...................... 1.997-1.999 (50.724-50.775)
No. 2 ........................ 1.980-1.982 (50.32-50.37)
No. 3 ........................ 1.965-1.967 (49.94-49.99)
No. 4 ........................ 1.949-1.952 (49.53-49.58)
Oil Clearance .................... (1) .001-.004 (.03-.10)
(1) - Wear limit is .005" (.13 mm).
VALVE LIFTERS SPECIFICATIONS
VALVE LIFTERS TABLE
Bore Diameter ................ .9051-.9059 (22.990-23.010)
Lifter Diameter .............. (1) .903-.904 (22.94-22.96)
Oil Clearance .................... .0011-.0024 (.027-.060)
(1) - Standard diameter valve lifter is listed. Oversize
valve lifters are available in .001" (.03 mm), .008"
(.20 mm) and .030" (.76 mm).
Track - 62.0 in.
3.3L V6:
Type - OHV 12 valve
3.5L v6:
Source: allpar.com
Crankshaft
Main Bearings
Pistons
Pins
Rings
No. 1
No. 2
No. 3 (Oil)
Cylinder Bore
Intake Valves
Exhaust Valves
Valve Springs
Free Length
Pressure (1)
Valve Closed
Valve Open
CYLINDER HEAD TABLE
Valve Seats
Valve Guides
Intake Valve
Valve Stem-To-Guide
Exhaust Valve
Valve Stem-To-Guide
CAMSHAFT TABLE
Lobe Lift
Main Bearings
Pistons
Pins
Rings
No. 1 & 2
No. 3 (Oil)
Cylinder Bore
Intake Valves
Exhaust Valves
Valve Springs
Pressure (1)
CYLINDER HEAD TABLE
Valve Seats
Intake Valve
Exhaust Valve
Valve Guides
Intake Valve
Valve Stem-To-Guide
Exhaust Valve
Valve Stem-To-Guide
its seat.
its seat.
Journal Diameter
VALVE LIFTERS TABLE
