I have a 95 3.5. I have a squeak on the front driver side, coming from the wheel. It is a metallic squeak. As I speed up the squeak speeds up till I start going fast enough the ambient noise conceals the squeaking noise. I installed new rotors and pads in the front. An interesting thing I notices was that the driver side brake pad (the side which is squeaking) was down to the rivets where as the passenger side had about 25% left on it.
Putting in the new rotor and brake pad did not help! I read thought other posts, I do not have the thin metal sheet (dust cover or what ever it is) so that is not rubbing against the rotor.
Any suggestions?
Any one know what it is?
Thanks
Any suggestions?
Thanks
